-   -   timing a 7.4 mpi motor (https://www.offshoreonly.com/forums/do-yourself-boating-budget/232275-timing-7-4-mpi-motor.html)
ken3765 06-08-2010 07:41 PM
i need some help timing my 2000 gen vi 7.4 mpi motor. i need to know how to set the base timing. i understand the timing should be 8 degrees as per the valve cover. i recently had the motor rebuilt and have it running pretty good as per setting it by hear.
ken3765 06-16-2010 09:13 PM
wow no one can help, i am surprised :coolcowboy:
ThruHull 06-17-2010 07:07 AM
You need to jump pins A & B on the DTC connector to put the motor into base timing mode. Start engine and bring to 1500rpm, then set timing to 8 degrees.
