Need some opinions on engine build >
Old 06-09-2010 | 09:57 PM
Default Need some opinions on engine build
hey guys, i know most of you are running bigger boats with higher hp but i think you could maybe give som valuable input. I have a 1987 Concord Magnum II. Its 20 ft in length and weighs about 2500 lbs with a 260 hp merc 5.7L. it runs on GPS around 53-55 at 3000 ft above sea level with a 21p laser II. I am currently building another engine for it. It is a 97 vortec 350. I am using an edelbrock performer rpm intake, vortec heads, 9.72:1 forged flat top pistons, the original qjet, and switching to a roller cam and roller rockers. the rockers are 1.6 and the cam spec is 218 degrees at .500" on the intake side and 228 degrees at .500" on the exhaust side with 112 degrees lobe seperation. the cam actually gets .525 lift with the 1.6 rockers. was wondering what kind of power i can expect at 5000 rpm and maybe what kind of prop i should use to get max bow lift and top speed, also maybe an estimated speed.
87MagnumII is offline
Old 06-09-2010 | 10:38 PM
I don't know if you're planning on running the stock exhaust, if so don't. There is/was a nice set of SB stainless marine exhaust system in the swap section.
endeavour32 is offline
Old 06-09-2010 | 10:46 PM
what would be the issue with stock exhaust??
Old 06-09-2010 | 10:53 PM
The stock stuff is junk from a performance standpoint.
You are talking about lots of time money and effort.
Is this the platform you want to invest in?
Uncle Dave
Uncle Dave is offline
Old 06-10-2010 | 07:16 PM
Uncle Dave
Give him good advice Uncle Dave, tell him to buy a faster boat.
Sunshadow is offline
Old 06-10-2010 | 07:33 PM
Boy ...on one hand I mod everything so its hard to say that.
If you want to do it and you a a very capable guy well help you.
87 the size of your boat isnt the issue, its the viability of it as a performance platform - Oh you can get there...but its likely going to cost more than you think.
I would also say that you are likely to be frustrated with the end result and astonished by the price.
87Mag- alpha or Bravo? Whats you TOTAL budget?
If it were me - Id simply play with props and enjoy what is probably a really neat boat that runs well and doesn't give you any problems.
is this semi close to what you have?
http://www.concordboats.com/Magnum-II.html
Uncle Dave
Old 06-10-2010 | 08:16 PM
Uncle Dave
Agree after working on my own little project I've spent about 2 k more than I thought and I'm still not quite done. http://www.offshoreonly.com/forums/d...3-eclipse.html
Old 06-10-2010 | 10:21 PM
Nice project, its coming along. Ill do some more reading- nice documentation I know how time consuming it is.
Hey...does your girl have a sister?
Uncle Dave
Old 06-10-2010 | 11:46 PM
Uncle Dave
thats the exact boat i have, differnet colors but you get the idea, and by the way i have less than a $1000 in the whole engine project, the block and heads were freebies, i know im not going to get 100 mph out of this thing but i was hoping for mid 60's. its a 20 ft boat, how fast do i really need to be going anyway? lol
Old 06-10-2010 | 11:47 PM
its an alpha drive by the way, forgot that earlier
