How To: Rebuilding Merc Sea/Fuel Pump
Hey Mike. I've never used those pumps. My engines are the old Mark IV's. I run the self regulated block mounted 6 valve mechanical pumps. I love them. No regulator needed, and will support a ton of power. Same pumps merc used on the 900sc and 1000sc.
For some reason in my head, I thought the merc pumps were made by carter? I honestly don't know. I do know, I used an Airtex pump in my dually, (in tank electric), and it lasted about a week. Switched to a Delphi pump, no issues.
CV products makes a bad azz pump for the seapump deal. Quite expensive though!!
I have no reason to believe the Airtex pump was the cause of the vaporlock.
http://www.fuelairspark.com/fas/ez-e...-base-kithtml/
How are things going Mike? Mines all ready to hit the water. Just did oil changes today and fired them up for a quick sec. You guys going to make it up towards West Mi this year or are we going to have to meet in the middle somewhere. And Joe are you going to join us?
Imp viper in other nite . Made him get down there and pull the screws out of those pumps . One half full other empty. He got lucky . Use merc green drive fluid . If you put droop hoses on your combo pumps the green fluid does a swell job of kicking any water that gets through to the bottom ,or down into your clear sight hoses. Good mod on a expensive pump like that .
