Head swap
Old 07-01-2010 | 01:39 PM
Default Head swap
Ok, my mystery miss is looking like a bad bvalve...Have to do a compression check first, but am getting ready for a head swap. Haven't done these in about a hundred years...Need intake and head gaskets..Anything else I'm forgetting? Thanks! Den
Den P is offline
Old 07-01-2010 | 10:40 PM
Will be finishing up one myself this weekend, bent valve on #6 Intake of port motor. If you are using a Gen IV block like me you will need the Felpro Marine Head Gasket #17040, also use the associated intake and exhaust gasket set. Good Luck!!!
cliff_m_b is offline
Old 07-02-2010 | 09:27 AM
Rookie's Avatar
exhaust gaskets, valve cover gaskets (if yours are not reusable) and a tube of the Right Stuff for the front and rear of the intake.
Rookie is offline
Old 07-02-2010 | 09:33 AM
Ted G's Avatar
You also need a bottle of Merc Perfect Seal for the intake gasket water ports, don't ask how I know this
www.cbpba.com
Ted G is offline
