alpha 1 counter rotate
Old 09-09-2010 | 07:08 AM
Default alpha 1 counter rotate
I have been searching for the last month and a half for a counter rotating alpha 1 gen 1 right now I have 2 standard rotating drives. They sell those SE stuff but im a little scared of that stuff and new mercruiser stuff is pretty expensive does anyone know of a shop around st. louis that I may wanna try I tried every shop I know of around here any help would be great
rjh12904 is offline
Old 09-10-2010 | 08:57 AM
anyone
rjh12904 is offline
Old 09-10-2010 | 09:30 AM
Any used CR Gen I Alpha that you pick up will be a gamble, with 20+ year old parts in it. The SE stuff with a warranty might be a better way to go, if you can talk to people that have bought them.
floatingphil is offline
Old 09-10-2010 | 12:54 PM
anyone know anyone who has used that se stuff
rjh12904 is offline
Old 09-11-2010 | 01:15 PM
spazboz's Avatar
Not the CR unit, but I am running a std. rotation SE on my powerplay. I had it on for about 4 years now and have had no issue's.
spazboz is offline
Old 09-12-2010 | 07:53 AM
I was just thinking about this I read all you have to do to install the counter rotate is swap the shift cables but then what about the impeller setup is it still a standard impeller
rjh12904 is offline
Old 09-12-2010 | 08:31 AM
not on alpha's..bravo yes
ezstriper is offline
Old 09-12-2010 | 01:05 PM
I would just get an SEI drive. I have never heard of anyone having problems with them other than the paint is not that good.
Griff is offline
Old 09-17-2010 | 10:01 AM
I had a 87 Scarab that had Alpha drives on it and one was the CR drive. To answer your questions, The impellor is the standard one, it does not spin backwards. On the CR alpha, the only thing that spins reverse is the lower gears. It was told to me that the CR drive has a slightly beefed up reverse gear(which is actually the forward gear). It was always a pain and was the one which would blow up, but I did have 454s pushing them. Whenever I replaced one I got it from Jasper Engines as a factory rebuild.
rumrunner29 is offline
Old 10-05-2010 | 04:17 PM
I think all you need is the lower unit. Last time I looked the SE's were around $800 for a CR lower.
jtmarten is offline
