Runs great for a little while >
Old 09-25-2010 | 07:21 AM
I had similar issues with my 454 (its older than your's 1987) i did everythign, i thought it was losing fuel also I would have dropping revs a sometimes just loose power for periods of time.
Nothing worked until I found out my timing was off 4 deg, new distributor cap, button, and new plugs and wires. while i was working on i found out the main wiring harness was loose and realt dirty inside i cleaned it out too. made a big difference in performance.
derekmc1 is offline
Old 10-01-2010 | 09:58 PM
Took the boat to the shop. They found that the longer the boat ran the less voltage there was at the dash. They ran a new 10 gauge wire power wire to the dash and it seems to be fixed. I hope to test run it for myself Sunday......Thanks for the Ideas and suggestions.
douglasp is offline
Old 10-01-2010 | 10:08 PM
Throttle Fever's Avatar
Good deal, glad you got it figured out. Let us know how she works out...
Throttle Fever is offline
Old 10-03-2010 | 09:30 PM
Test drove today and I believe its fixed. A very expensive piece of wire from battery shut off to the key switch....just glad its fixed......Now where did summer go?
douglasp is offline
