-   -   Low Oil Pressure!!!! (https://www.offshoreonly.com/forums/do-yourself-boating-budget/239444-low-oil-pressure.html)
92stingray502 03-12-2011 09:34 AM
i am planning on replacing the cooler and oil lines. my cooler also cools the power steering. does one need a cooler on the power steering?
92stingray502 03-15-2011 08:44 PM
Originally Posted by blue thunder (Post 3348604)
I use to think this was bulll****t. That's until I tore an engine down after not changing lines and cooler after a blowup and saw terrible bearings with tons of crap run through them. The engine still ran fine but it was subjected to much debris and its life was going to be short if I didn't tear it down again for other reasons.
did you clean the cooler and lines at all when you put it back on?
blue thunder 03-16-2011 09:39 AM
Yes, much cleaning. Diesel fuel and compressed air. You just can't get it all. It gets driven into the nooks and crannies under 60-80psi. Then seems to reenter the oil path randomly. It's hard enough to build one clean without sabatoging yourself.
ezstriper 03-16-2011 09:59 AM
I have a complete setup from a 98 502 EFI mag, all clean, just upgrading if anyone is interested...Rob
tsayvan 03-16-2011 01:04 PM
Is it the entire engine??
Looking for a 502 block but if I have to ill buy a complete engine.
Thomas in Louisiana
92stingray502 03-16-2011 01:12 PM
Hey Thomas contact sonicss42. he has a motor for sale. i think he posted in this thread some where.
