Which oil filter for my 454? >
Old 09-28-2010 | 11:38 AM
Default Which oil filter for my 454?
I have a 1989 Mercrusier 454 and I think it may not have the correct oil filer on it. Currently it has a WIX 57099 mounted to a remote oil filter bracket. Should I replace it and use the same model or should it be somthing different?
drpete3 is offline
Old 09-28-2010 | 11:59 AM
c_deezy's Avatar
Looks like you have the correct one:
http://www.wixfilters.com/filterlook...&Submit=Search
c_deezy is offline
Old 10-18-2010 | 07:27 PM
STP has a bigger filter then the standard GM size. I think it is an STP 3376. Just my two cents
79excalibur is offline
Old 10-19-2010 | 10:15 AM
I'm running a mercruiser on my BBC. I asked a buddy about maybe changing brands and he said I was better off staying with the mercruiser because they have higher flow volume. Does "anyone in the KNOW" have knowledge about this? I would like to hear some smarts on "which" filter and "why".
Thanks...TS27
Thunderstruck27 is offline
Old 10-19-2010 | 10:31 AM
Ted G's Avatar
More than you ever need to know:
http://www.offshoreonly.com/forums/g...brication.html
www.cbpba.com
Ted G is offline
