not getting fuel to filter
VP of the tickfaw200
have a 2000 baja with a 502 mpi. the pump is priming but not sending any fuel to the filter. is the pump bad or cloged line some were befor the filer or befor the filter. changed the regulator pump and fuel cooler about a year ago. it has also been burning more gas then normal.
I have seen some cool fuel systems that have cracked the cooler and the fuel goes out through the cooler into the water for cooling. Also you have a anti drain back check valve at the fuel tank pickup. Unscrew it at the fuel tank line and see if it has an object in it or the spring messed up.
Yes I filled it first ran untill it burned what was in the filter. Also checked to see if any gas came out with out the filter on, but no gas at all just a drop or two.
while you're at it, make sure you check that your fuel pickup tube is in tact. I've had more than one break off and end up in the bottom of the tank. It's one of the first things I look for now when i have a lack of fuel issue.
