98 502 camshaft
Old 10-02-2010 | 06:32 PM
Default 98 502 camshaft
I have a gen6 502 in need of a camshaft. I would like to upgrade it just a tad bigger or should I just use the stock cam. I changed to aluminum heads and better pistons with the same bore with a higher dome. I'm not looking to get major hp just looking for a good running engine without having to worry about reversion. If anyone has a stock 502 roller cam or something a little bigger. send me an email [email protected] Thanks Jeff
alecsammy is offline
Old 10-03-2010 | 09:23 AM
I have two brand new roller cams, springs and retainers out of Gen VI 502's. $100 each plus shipping.
1BIGJIM is offline
Old 10-03-2010 | 01:31 PM
If you go with a cam bigger than stock you should get aftermarket exhaust with long risers. If you cannot afford the exhaust I would just use the stock cam.
jeffswav is offline
Old 10-04-2010 | 09:27 PM
A buddy has a nice comp cam hyd. roller that is around 560 lift made very good power, he went bigger. probably less then 20 hrs. on it. I'll check with him tomm. if you want?
speedreeder is offline
