Oil Change???
Old 10-07-2010 | 05:24 PM
I have been doing everything backwards for the last 24 years. I change my engine oil in spring, so I can have fresh oil on my valves so I don't start the engine dry. One year I changed my oil in the fall, but when I started it up in the spring, it was very very rough. I'm not doing that again. I use Mobile 1 synthetic. I change my drive oil in the Fall. Maybe draining your oil in Fall, fill it up half way, then fill it up to the top before you start it in Spring so you don't have a dry start would be the best thing. After reading this post, I'm going to try that, as it makes the most since to me. Also cost effective.
UrbanDisturbance is offline
Old 10-07-2010 | 08:18 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Originally Posted by mookymonkey
what i normally do is heat the engine up. change the oil. winterize the engine. then we change the drive fluid just in case. that way in the spring everything is fresh. good insurance and peace of mind...
been doing it this way for yrs. Always changed drive oil for a looky see at the color of the lube.
US1 Fountain is offline
