Help - 496HO won't start
Old 10-24-2010 | 10:52 AM
Default Help - 496HO won't start
I was out running around yesterday cruising around 55-60mph. All of a sudden the starboard tach started jumping all over the place and the motor died. It cranks fine but won't start. It smells like it's getting fuel. I pulled a plug wire and didn't see any spark while cranking. I plugged in the techmate and it didn't have any codes. I also ran the ignition test and it said it was all good.
Any ideas?
Thanks,
Ed
OutlawEd is offline
Old 10-24-2010 | 01:41 PM
Fixed! I'll post later explaining what I found.
OutlawEd is offline
Old 10-24-2010 | 01:56 PM
Default engine want start
Was it a ground issue??
Hank36 is offline
Old 10-24-2010 | 02:10 PM
obnoxus's Avatar
Charter Member #1171
pluged the lanyard back in !!!!???
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 10-24-2010 | 09:33 PM
No and No. It was a blown fuse. One of the 4 fuses in the block shown in this picture was blown. Anyone know what these fuses are for? It obviously was preventing spark.
OutlawEd is offline
Old 10-24-2010 | 10:23 PM
Was it an actual "fuse" or relay?
I think I just lost the same thing a while ago. Could still hear your fuel pump run at key on?
SDFever is offline
Old 10-24-2010 | 10:35 PM
Nope, not a relay. I know the picture is kinda blurry. But it's a block of 4 20A fuses.
Fuel pump was running fine. I pulled a plug and had my wife crank it. There was no spark. Replaced the fuse and it fired right up.
OutlawEd is offline
Old 10-24-2010 | 11:28 PM
Default Want start
Glad you got it figured out..
Hank36 is offline
Old 10-24-2010 | 11:40 PM
Cool
It was the power for The spark Module/Amp.
Keep it dry and Make sure the connections are clean and coated with dielectiic coating..Oxidation ruins electronic parts.
Have a Great Day!!
bigem1 is offline
