help SEAWATER PUMP??
i'd change out the impellor and housing in the spring, and also install a fresh water flush setup (hose fitting on transom or in bilge that ties into the input hose). then you can get rid of the muffs (cup).
After putting in a new raw water pump I would also install one of these and forget about the muffs - http://www.perko.com/catalog/categor...e/product/62/e
That thing is pretty slick.
Has anyone used the brass housing for the stock pump? What about the Globe "run dry" impellars. Brian
http://cgi.ebay.com/ebaymotors/HI-PE...ssoriesQ5fGear
