Engine advice needed please >
Old 11-13-2010 | 12:50 PM
Ona-Mission's Avatar
Default Engine advice needed please
I have a pair of gen 4 502 blocks and twice now I have dropped valve seats out from number 7 cylinder and also tuliped vales and burned a hole in the valve on the starbord motor. this same thing has happened on two totally different motors on the same side. that same cylinder on the starbord motor the spark plug regularly comes loose. both motors have had the same dart intake, proline carb, thunderboth ignition, and combination mecanical fuel pump backed up with an electronic fuel pump. Just prior to this most recent motor mishap I replaced the thunderbolt ignition module and also scrapped the combo fuel pumps and installed one good mecanical pump.
Is this a common problem with valve seat on this gen 4 motor?
Is this a common problem caused by the gen 4 block?
Is this a thunderbolt problem?
Fuel issue?
intake issue?
Ona-Mission is offline
Old 11-14-2010 | 01:26 AM
Sounds like it is running lean and the cylinder temps are too hot.
Griff is offline
Old 11-14-2010 | 04:51 AM
What spark plugs are you running? Part number?
Could be an intake flow issue as well.
lakematdude is offline
