Alternator/Electrical "guru's" Please help >
Old 12-20-2010 | 01:31 PM
Is it worth the extra money to go with a lightweight "gear reduction" style starter? I know they are quite a bit lighter and draw less amperage, do they hold up well in a marine environment? The motor is stock, so, its not hard to turn over, but, if I have to change it anyway, I might as well upgrade it now, as opposed to later
Thanks!
Michael
n20michael is offline
Old 12-20-2010 | 06:56 PM
Audiofn's Avatar
Charter Member #232
Yes your ground wire should be the same size as your power wire. You are only as strong as your weekest link...
Put your best foot forward!
Audiofn is offline
Old 12-21-2010 | 06:54 PM
Thanks Audio!!
Do I upgrade the negative battery cable? Or is there an actual "ground" wire that attaches to the alternator/starter? A print or diagram would be REALLY awesome!
Thanks!
Michael
