Painting/ Coating of stringer? >
Old 01-21-2011 | 04:45 PM
Are you able to apply these coatings without sanding the fiberglass. Going through and resanding all the stringers and bulkheads does not sound fun.
bigmike253 is offline
Old 01-24-2011 | 03:33 PM
Bump cuz I need to get movding on this part of the project
Old 01-25-2011 | 12:30 AM
I know it's a little late but this is what I did. (A snip from the SuperNova24.com website)
This is how it’s going to happen. Drill a ½ inch hole in the top every foot or so. Drill a inch and a quarter hole in the bottom every five feet or so. Grind up anything on the inside and fish it out through the hole in the bottom. Sounds easy enough.
SuperNova Race Boat
This is a little of what it took to get everything out of there but the most important tool is not there. My trusty Shop Vac. I would start with the hole over top of the bottom outlet hole. Grind up the stuff inside, fish it through the hole and then move out from there.
After 3 days of this I now have stringers in a can.
SuperNova Race Boat
I was lucky. For the most part what was left of the wood came out pretty easy with my assortment of tools. Drill, drill, push out with a chunk of all thread. Repeat with some chopping and breaking up chunks with needle nose pliers. Suck it all up with the shop vac. I think I got it all where it was bad. There is one spot I want to go over again tomorrow that may require pulling the bolts out of the V drive plate but this is a one time thing and will be done if necessary.
SuperNova Race Boat
Stringers in a can.
I love this stuff. Searched for something like it for a long time when I had to fix the 19’s strikes. I forget who mentioned it but I do owe that man a beer.
Man, ever since I started this project I have been afraid of this happening and now it’s here.
SuperNova Race Boat
What a mess!
SuperNova Race Boat
I got all the access holes I cut ground down and glassed over. Then sanded and painted. Only got one coat of paint on. It was taking forever to dry so I gave up. I still have four holes in the top if the last stringer to fill so I can put another coat on then. The last 4 holes will be hand sanded this time to keep the dust down. I thought about it for about a second when doing the other holes but gave up on that real quick. I thought it would have been easier just to clean the boat after. Hummmmmmm……
Last everything was painted with 1 part epoxy garage floor paint. Got it from the Home Depot oops cart. 4 gals for 20 bucks.
f_inscreenname is offline
Old 01-25-2011 | 05:25 PM
So to answer my question can this stuff be brushed on to the stringers without sanding?
Old 01-26-2011 | 02:10 PM
There was a grey coating already applied to the fiberglass from the factory/builder. I cleaned the crap out of it and then wetvac all the water out, towel dry every square inch and then painted over the grey. No, I did not sand it first because I was applying it over an existing coating. The SW duraplate235 worked very well and only time and use will tell how it holds up.
high bid is offline
Old 01-26-2011 | 04:38 PM
In my opinion any time you're going to repaint something prep work is needed. It may be just cleaning and a light scuff sanding so the new product bonds properly, or up to possibly needing to completly sand off an existing coating, prime then apply the new coat. It really depends on what you have on there now and what the new product will be. There can be compatability issues. Neverthess the minium should be a good cleaning and scuff sanding when you apply a coating that is compatable with an existing coating, assuming that the existing coating is already bonded well. It that's coming up you're looking at a full sand down.
I'm currently looking at recoating an engine room where a previous owner did not properly prep the suface before applying Interlux Bilge Kote. It's actually very nice product but it's all peeling off and looks like heck because the guy simply did not properly prep the surface. When or if the engines get removed we have to completely sand everything off and then prime and coat. I wish the guy has jsut left it all alone it would have been easier.
The easiest thing to do is if you have any coating on there now find out what it is then and look for a product that's compatable. If you find a compatable product you still should do a good cleaning and mild scuff to enable a good bond you really want to do it right.
rrrwel is offline
Old 01-28-2011 | 08:39 PM
I wear many hats at my company, which is an industrial painting contractor. I am a UHP Technicial, Maintenace Supervisor, Robotics Consultant, Nace Certified Paint Inspector, etc. Just depends on what permit or visa we need.
To Answer your questions. Possibly Yes and Yes for sure.
While the expoxy resin is waterproof, if the boat was orginally of poly ester or vinyl ester resin, whatever you ground and exposed needs to be painted. Poly/vinyl ester resins are not 100% water proof, thus the need for gelcoat or paint.
As far as sanding the epoxy resin, that depends. How long is the recoat window? Some coatings I deal with have no recoat window and must be sanded if any recoat or touchup is needed. Some others only need degreasing and pressure washing up to 6 months. You will have to read the spec/data sheet on the resin and determine this. If in doubt, wash with soap and water, lightly sand with 80 grit or so, rewash with soap and dry, then paint.
I personally would wash everything with a good water based degreaser, lightly sand EVERYTHING you want painted, rewash with soap and water, thoroughly rinse everything with clear water and dry, then apply an epoxy paint.
Your average expoxy coating is very waterproof, but does not have any UV protection. Anything exposed to daylight needs to be UV compatible or it will chalk up, loose gloss, and generally get ugly in a short period of time.
Sorry for being long winded. Just happens to be something I know a little something about, lol.
Patrick
uhpguy is offline
Old 02-24-2011 | 07:10 PM
alright guys I still cant decide what to do. I redid all my stringers and bulkheads recently, the boat has no floor in and is just the exposed stringers and hull. What I noticed in some spots of the finished product was some very fine pin holes in the fiberglass. My original idea was to use interlux bildgekote to help protect the fiberglass on the stringer and bulkheads from water damage. But after taking a harder look in to all the prep that goes in to it I'm not so sure if it is worth it. I would have to sand everything down from the rear bulkhead all the way to the tip of the bow thats about a 1-2 day job, then paint and let dry, then sand again, which is another day or so, then paint, and sand, and paint........you get the idea. Thats about 5 days worth of work...is there anything out there that can be applied to bare fiberglass that has a thick and resistant shell? The fiberglass is in good condition I guess I'm just looking for a different product that will be less time consuming to apply. And one last thing, this area shouldn't be getting wet anyway, so am I just being a little over protective?
Old 02-25-2011 | 12:58 PM
Seriously, check out the SW Duraplate 235. Any SW commercial location had the spec sheet and details.
high bid is offline
