HP 450 assembly question
Old 02-08-2011 | 02:24 PM
Donzinator's Avatar
Default HP 450 assembly question
Im reassembling my 7.4L HP 450 (after the Gen V block was overheated and cracked) Upgraded to Gen VI block and was wondering if there was any reason for not using the oil passage o-ring between the #5 bearing cap and block.
The only reason I ask is when I disassembled the old block the o-ring was missing. Is this normal or did some one forget to install it last overhaul.
Thanks for any help.
Donzinator is offline
Old 02-08-2011 | 02:39 PM
I'd say someone forgot it. It's inexpensive, put it back in.
Boat1 is offline
Thunderstruck's Avatar
The oring is supposed to be installed. Go ahead and put it back correctly.
Long time cult member.
Thunderstruck is offline
Old 02-08-2011 | 02:47 PM
Donzinator's Avatar
Talk about fast service.......not even 20 minutes for a reply!
Sounds good to me. The only reason I could have thought not to put it in would be if it deteriorated or broke it could make it's way through the oil system and get stuck somewhere important!
Thanks for the info.
Old 02-08-2011 | 07:34 PM
Oring comes in the pack with the genv/vi 1 piece rear main seal.
