496 Stroker - Help me with a reasonable build >
Old 02-15-2011 | 04:18 PM
wow, w/the $$$$ you're speding I'd a gone w/diesels!
Far more economical and will def meet your TQ specs.
JMO
high bid is offline
Old 02-15-2011 | 04:49 PM
JMO
That would be a cool project, not many guys run diesels
jeffswav is offline
Old 02-15-2011 | 05:34 PM
I hear Ya,
I actually did consider it and priced it out but the costs were out of this world to convert. It was 70K to convert to a pair of Cummins B series. I know this may be hard to believe but after running all the prop, transmission and performance numbers my boat will actually cruise a bit faster with the gas strokers. Of course I'll be getting only about .65 gals per mile with gas as opposed to a better 1 mile per gallon with the Cummins. But with diesel costing more than gas plus the 70K it just doesn't make sense for me.
rrrwel is offline
Old 02-15-2011 | 06:10 PM
Originally Posted by rrrwel
Thanks,
Learning a lot here. How would I go about lowering the CR down to 9.0? Should I be looking at the cam specs that jeff1000 posted on his dyno sheet? I do always run 89 octane.
You just have to get different pistons to lower the CR. You can also make small CR changes with head gasket thickness and porting the combustion chambers.
I would get with Bob Mandera/rmbuilder on the best cam for what you want. I would think a cam with a 114 lob sep would have a flatter torque curve and maybe something with more like a .580 lift. That way it makes its peak power and torque lower in the rpm range where you need it.
Griff is offline
