Sometimes if you're nice your local marine mechanic will lend you his alignment tool. Can't hurt to ask.
Originally Posted by Slamdit
(Post 3345324)
Thanks for the help. The shop rebuilding my motor has alot of marine experience so I feel good there. I didn't realize I needed to take off the outdrive to install the motor but it now makes sense to make sure everything is aligned. I am a decent mechanic but my experience with boats is very limited. Thanx for the help, I knew it seemed to easy just to drop the motor back in.
Sean |
Originally Posted by Ted G
(Post 3345396)
Trust me it is alot easier dropping it back in with the drive off. And I too have one of Whoya's tools and it is great. It is a little nicer than the Merc tool.
Agreed on pulling the drive off - it is 6 bolts and about 5 mninutes worth of work.... |
Bottom line is you need to take the drive/drives off when you are going to remove the motor/motors. I've seen guys do it without removing the drive,actually one guy and he had to remove the drive after to align it.
Save yourself alot of trouble and money. Remove the drive first before you remove the motor. The transom assembly has two spring washers that make it very hard to remove the motor with the drive on. When you put a motor in you drop it down on to the spring washers,thus trying to pull the motor forward will be very hard unless you pry the bell housing up from the transom assembly spring washers. |
Im trying to find the alignment tool link on here and can't. Could someone please help me out?
thanx, Sean |
| All times are GMT -5. The time now is 06:55 PM. |
