Degree Wheel
Old 03-16-2011 | 07:19 PM
Default Degree Wheel
Will a 11" degree wheel be fine? Dont want to go crazy over something for a 1 time use.
or is there a expierenced person with one in the s. florida area. Deerfield beach?
Should have cam early next week. Thanks
pantera232 is offline
Old 03-16-2011 | 07:55 PM
Default Fixx
It will work fine..after you find tdc they all work the same..after you find tdc make sure the line on the ballancer lines up with zero also..they have been known to be off a few degrees from the factor..
FIXX is offline
Old 03-17-2011 | 06:57 AM
They are low in price and give a piece of mind. Advance the cam a few degrees and you will gain some added torque that really helps in a boat. Depends on what you are looking for. Advancing the cam say 4° in a 525efi will gain you a couple of mph's.
I degree all the cams I have put in and they have all been right on per the cam spec's. Again, piece of mind.
29Fever575sci is offline
Old 03-18-2011 | 05:46 PM
Appreciate it guys hoping to have bob m cam by wednesday
781 heads
Forged 9.25;1 113.8 CC DOMES
.025 DECK HEIGHT WITH .027 COMETIC GASKET
ANYONE EVER RUN 781 WITH DOMES BEFORE? SHOULD I WORRY ABOUT VALVES?
