Question about installing dual guages >
Old 03-20-2011 | 03:23 PM
berns29scarab's Avatar
Default Question about installing dual guages
Looking to install a 2nd set of guages on my boat. Its a 500efi and looking to add a 2nd oil pressure, oil temp, and water temp to the passenger side. can this be done by piggy backing off the exisisting guages or do seperate wires need to be run from the guage to the senders ?? Thanks
berns29scarab is offline
Old 03-21-2011 | 03:10 PM
I believe you can piggyback the senders. However, I would recommend installing them on their own senders. For example, on the oil temp, lets say you are reading temps right now before the oil cooler. It would be nice to add a sender, after the oil cooler, and have that gauge on the passenger side. Normally, there is enough places on the engines to add additional senders.
MILD THUNDER is offline
Old 03-21-2011 | 03:18 PM
Bern what happened to your same thread from yesterday ????????????????????????????????????????
Old 03-21-2011 | 10:09 PM
You might need "dual station" senders if piggy backing.
speedjunky 123 is offline
Old 03-22-2011 | 08:28 PM
looks some some stuff was poofed
Old 03-22-2011 | 08:29 PM
yes i believe you are correct and that will solves any ohm/resisitence and they SHOULD register correctly and the same
Old 03-22-2011 | 11:51 PM
WTF
