454mag
Old 04-09-2011 | 11:44 AM
Default 454mag
upgrade horsepower/1997 454 mag was told to dump to 496. i am partial to motor and wallet
laser270 is offline
Old 04-09-2011 | 06:31 PM
How much more power will you gain make sure it is worth the money, unless 454 is worn out
firehawkcat is offline
Old 04-09-2011 | 10:24 PM
I'm getting mine freshened up with new cams, lifters, springs, rocker arms, little more compression. Target is 500 hp with the upgrades. Going to cost about $3500 a engine. Using same heads, intake, and carb. I couldn't see buying new blocks, when I could get reliable hp increase out of what I had.
pitts1313 is offline
Old 04-10-2011 | 02:18 AM
JasonSmith's Avatar
A +1/4" stroke crank over your stock crank will yield 496" in your 454 block.
JasonSmith is offline
Old 04-10-2011 | 10:27 PM
Definitely what I was going to do if my bottom end had needed work.
Old 04-17-2011 | 07:20 PM
hey pits1313 what carb size u running witht the 500 hp 454???
pantera232 is offline
Old 04-17-2011 | 07:40 PM
Who told you that? Stop talking to them
jeffswav is offline
Old 04-17-2011 | 11:08 PM
Using the stock weber carbs, 750 cfm. I haven't gotten the motors back yet. I have seen on here some bump the carbs to 800 cfm. Got all my engine parts thru marine kinetics.
