Starter problem
Old 04-18-2011 | 02:47 PM
Default Starter problem
I have a 300 tempest 350 and I need some help dissecting the starter problems. I tried starting it up 3 weeks ago and when I did it sounded like the starter was grinding. I unbolted it and looked for damage, everything looked ok then I reinstalled. I then tried again about a week ago and the engine turned over with a few cranks, then started to grind again. I tried a third time yesterday and it just ground...this is getting frustrating. The engines haven't been started in about 1.5 years. Any ideas as to what it could be. I see two starters were offered for that engine dependent on the flywheel size and I believe the right one is installed. Where do I start??
bigmike253 is offline
Old 04-18-2011 | 02:49 PM
blue thunder's Avatar
It could be hydrolocked. Remove the spark plugs and see if it cranks normally.
blue thunder is offline
Old 04-18-2011 | 03:15 PM
Next time you remove the starter take it to a starter rebuild place or an automotive parts house and have it checked out for a "load" test. This way you will be able to see if it is kicking in all the way and how many amps it may be drawing.
Cliff
cliff_m_b is offline
Old 04-18-2011 | 03:59 PM
If it was hydrolocked wouldn't it not turn over? or maybe it turned over enough to compress a cyclinder with possible water in it?
Old 04-19-2011 | 11:20 AM
It depends on how much water is in there. Regardless, you need to not crank it anymore with the spark plugs in until you verify it is not water in the cylinders.
If you had a hung open exhaust valve from sitting it would take a big gulp of exhaust water on every down stoke of the piston.
Old 04-19-2011 | 12:24 PM
it sounds to me like the solenoid that engages the gear might be bad. I would replace the starter all together.
olmako20 is offline
Old 04-19-2011 | 12:30 PM
you also might be able to grease up the gear so it can engage easier.
olmako20 is offline
Old 04-19-2011 | 03:56 PM
Starter bolts may be the wrong lenght, (too long) engine sitting for a long time was enough load and cocks the starter. So now it grinds, you removed it, no problem reinstalled with the same bolts that are really bottoming out and not keeping the starter tight.
James is offline
Old 04-20-2011 | 09:33 AM
Does your starter have a support bracket? Mine didn't and I had all kinds of starter issues until I installed one. The bracket bolts from the end of the starter to the block and helps support the end and when cranking.
high bid is offline
Old 04-20-2011 | 04:02 PM
HighBid, No support brackets, only two bolts that bolt from the bottom of the starter upwards.
