Must be the day for starter questions? here's mine!
Hey Guys
Any input would be appreciated. Late last year my boat started to develop a really "weird" intermittent problem. when the boat was "cold" after sitting overnite or for an entire day. I would get in, turn the key and NOTHING would happen, no solenoids clicking, no change in volt gauge, it was like the key switch wasn't even hooked up? Sometimes I would turn the key 2 or 3 times and other times it would be 6 or 7 and then "bam" the boat would fire right up. I figured it was a loose connection, ground, bad solenoid, the "usual suspects" Here is the weird part: Once the boat has "started" once, it fires up on the first try for the rest of the day/nite. I was out one day last year and had to turn the key probably 1/2 a dozen times before it started at the dock, naturally I was a little nervous about going out in the river and not being able to restart the boat to get home, so, I turned the key and it fired up instantly, I went for a 30 minute run, shut the boat off, turned the key, and once again it fired right up. we anchored and swam for a few hours, decided to come home, and AGAIN the boat fired right up. I got back to the dock that nite, and when I came down the next day to go out again I had to turn the key 3 or 4 times before it would start? I have had this happen in numerous race/classic cars, but, it normally happens when the starter gets HOT, not when its Cold? I am thinking of changing the "key switch" and see if that helps, since all the other connections "seem" ok Any input? Michael |
im going with the slave solenoid try that. Otherwise if you have the Merc manual on the enging it has a battery of test to figure out what part is wrong. I would diagnose it the best you can before throwing parts at it. Check your batteries. Check all your connections for a good connection and no corrosion. Then start with cheap parts, slave solenoid, ignition switch. last choice would be the starter
Originally Posted by Fountain4402
(Post 3382313)
Where would slave solenoid be? On the starter or remote? Boat is a 1996 Baja, single 454EFI B1 drive,
Anyway to test it? Would a "regular" automotive solenoid work? What would cause it to only act up when it was cold? Thanks Michael |
Nutral safty switch? Try holding the key over to start it and wiggle your shifter.
exactly the same problem on my 496 it was the slave selenoid.
Does any of the accesories work before you hit the starter? Is so I agree slave solenoid.
If not I had that fuse block go bad. Long shot but check it if you still have it on. |
Originally Posted by n20michael
(Post 3382414)
1 Attachment(s)
Damnit forgot the pic
Thanks guys! I appreciate all the help, will try and diagnose it this week sometime, thanks again!
| All times are GMT -5. The time now is 01:22 AM. |
