No Oil pressure
Old 04-24-2011 | 08:39 AM
Default No Oil pressure
I am having an issue I did my summerize two weeks ago everything was fine yesterday installed hyd steering. I started the engine and to bleed the rest of air out and now I am getting the red light and needle is at zero. I swapped oil sending units and the gauge reads 10 psi and then nothing. I put a mechanical gauge on it and has 60 psi idleing warmed up. I was wondering anyone have this issue or ideas of what it could be.
Also I tested the sending wire by grounding it out the gauge moves to about 20 psi and thats it.
I am lost on this one
353Formula is offline
Old 04-24-2011 | 08:54 AM
thread sealer on adapter and sending unit can cause weird readings
ezstriper is offline
waybomb's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Active Streak: 90 Days
Get to the back of the gage and ground the sender wire.
If the gage now goes full scale:
Check the connections at the back of the gage, and any terminal blocks between the gage and the sender.
If it does not go full scale - bad gage.
waybomb is offline
Old 04-24-2011 | 01:29 PM
Thanks for the replys I figured it out loose wires at gauge
Old 04-24-2011 | 01:39 PM
Default Fixx
you pretty much sumed it up,,i would have to say that the gauge took a crap..advise,when testing gauges use a 1 wire test light as a isolater for the sender for the gauge,,grounding the S lead on the back of the gauge can distroy it..gaffrig gauge?? they have their own sender's,using another type may cause false readings..
FIXX is offline
Old 04-24-2011 | 08:49 PM
I keep several resistors in the range of 20-80 ohms. Or you could use a variable resistor/pot. Glad you figured it out
jeffswav is offline
