Valve Lash question.
Old 05-15-2011 | 01:06 PM
Default Valve Lash question.
454 Cu. Inch big block.
Hydraulic roller tappets.
Roller Rockers.
What would the valve lash be?
Thanks in advance for the reply.
Brian
Big Boys Toys is offline
Old 05-15-2011 | 01:23 PM
Zero. Bring down till all up and down movement in the pushrod is gone then give it 3/4 to 1 more turn and lock it down.
picklenjim is offline
Old 05-15-2011 | 04:46 PM
bring to zero then 1/4 for stock GM lifters. If you are using after market lifters follow the mfg's specs. Most H-Per Lifters are zero plus 1/16th of a trun no more than an 1/8th.
tunertech is offline
Old 05-15-2011 | 05:36 PM
or snug all rockers till no up/down play in pushrod. run motor to operating temp. take off valve cover. while running slowly loosen each rocker till you hear tapping. then slowly tighten it till there is no noise, then add 1/4 turn and lock down.
SINGLETGT is offline
Old 05-15-2011 | 06:04 PM
Do a search on this topic and you can read until tomorrow morning.
I always go zero 1/2 to 3/4 turn.
35 years ago I was taught to take the valve covers off and adjust that way. To big of a mess. I still have the oil deflecters in one of my tool boxes.
1BIGJIM is offline
Old 05-15-2011 | 06:09 PM
+1
Hard Charger is offline
Old 05-15-2011 | 06:55 PM
yea I actually have a set of valve covers dedicated for that for when my motor was hydraulic roller. Solid roller now, so now there is lash.
Going the messy route will make the most power tho from what I was told
Old 05-16-2011 | 12:40 PM
X2
Griff is offline
Old 05-16-2011 | 01:40 PM
txriverrat2001's Avatar
You do not set a solid lift cam with the engine running - is that what you're thinking?? No way no how. Get the spec's - exhaust is usually more than intake - follow the procedure for placing the cam in the correct position based on the other valve - use a feeler gauge and you're done.
IF I remember correctly - set the intake when the exhaust starts to open - set the exhaust when the intake is about half stroke to being closed...
Don't quote me on it - it's been a while...
txriverrat2001 is offline
Old 05-16-2011 | 02:44 PM
UHHHHH.......I don't think anyone was thinking that.
