Bravo Transom Seal
Old 05-20-2011 | 12:43 AM
Default Bravo Transom Seal
Has anyone ever changed one? I had a transom leak last year, changed the Gimbal ring/swivel pin, while it was apart I changed all the Bellows as well.
I still have a very, very small leak [more like a "weap"] nothing major, but, I would like the boat TOTALLY water tight, I have narrowed down the problem to the transom seal, I have the seal and adhesives now.
How hard is it to change? Does engine have to come out? any tips/idea's? I contacted a few local marina's, but, being late May most of them are SO busy they couldn't even look at it for a month and I dont want to lose 1/2 the summer waiting for it to get fixed, if its a "nitemare" I will probably just live with it and have it fixed over the winter
Any input appreciated
Thanks!
Michael
n20michael is offline
Old 05-20-2011 | 05:32 AM
Yes you will have to remove the engine. After that it is pretty straight forward.
tizbad4 is offline
Old 05-20-2011 | 07:33 AM
I had to have my whole transom assembly replaced last spring, started as a bellows job until the guy doing it realized at some point in time the u-joints blew apart and took out all but about a 1/4" of the ring the drive shaft bellow clamps to... Anyways, he and another guy came back the following weekend, lifted the motor out, unbolted trans ass. cleaned around the hole, and had it put back together and ready for boating in about 3-3.5 hours. I was amazed as I've never seen it done before. I figured if it was me doing it, I wouldn't even have had the motor out by the time they were backing out of my driveway, HA!
89Mach1 is offline
Old 05-20-2011 | 10:24 AM
Default Fixx
poke the wood around the transon for soft or rottin wood., uncommon for them to leak unless your in salt water..Their may even be a hole rotted through it..
FIXX is offline
Old 05-20-2011 | 11:36 AM
I agree.
Might have a soft transom that is flexing and allowing water to come in.
Griff is offline
Old 05-20-2011 | 12:52 PM
Transom is rock solid, had it checked last year, the boat WAS previously used in salt water, Thankfully with closed loop cooling [-:
Michael
Old 05-24-2011 | 09:09 PM
Hey Michael guess what......mine does the very same thing. I'm havin trouble finding the leak but I'm leaning toward the steering assembly. Sucks havin a boat that leaks!
rivermonkey is offline
