Adding trim tabs?
Old 05-26-2011 | 05:36 PM
Too Stroked's Avatar
Originally Posted by Eclipse232
What do you think the problem could be then? Also what would be wrong with using the tabs to level it out?
I agree with what others have said - that tabs are still a pretty good idea for a boat that size and mounted correctly, you will not loose any speed.
As for what's causing the boat to twist coming off a wave, I'm not convinced it's prop torque. Heck, I've got a 27" pitch prop on a much lighter boat and it comes off a wave perfectly straight. More pitch and more rake should twist the heck out of mine.
As for using tabs to even it out, think about that one for a minute. That would mean one tab is down more than the other. When a boat lands, the stern digs in and the effect of the tabs is magnified. That would mean you'd take a pretty good roll to the other side. Not my idea of having fun.
My recommendation would be to add a set of tabs anyway, but do some sniffing around for rigging and balance issues that might be causing the twist.
Too Stroked is offline
