mechanical trim indicators
Could someone post some pics of their drives showing how the system connects to the outdrive? I have them set up on my ram but they dont connect to anything else to make the cable move. Just need to see what I am missing.
This is the best pic I have right now. This was taken before I bought my boat and at the time the cable was rusted stiff(wouldn't move at all). The black rod that moves inside the stainless cylinder should move with the drive and butt-up to the stainless ring. You can see I wasn't getting any action since my cable was rusted. I have better pics, but not with me. I you need I'll send them but it couldn't be til after Mem. weekend. Good luck and watch out for the crazies this weekend.
As thundersruck said the black rod bumps up against that stainless ring. Spring pressure allows it to come out when you raise your drive. When you lower your drive the stainless ring will push the rod compressing the spring. If your cable is bad the rod won't come out when you raise the drive and your indicator won't move because cable isnt moving
When I bought my 32 Victory the port indicator bracket was goobered up and the cable was kinked and twisted on the end. I need to get a new cable and bracket but have not found a replacement yet. The starboard one works fine.
Gotem fixed. I used the standard teleflex cable for throttle control. But make sure your housing on the outdrive is packed good with grease.
Now If my parts for my drive shaft will hurry up and come in.
thanks everybody.
thanks everybody.
My port-sdie drive indicator is not working. I have a 29' Fever 2006. Killfast, what Fountain do you own and do you still have the replacement cable part # and recommendation as to where to purchase? I am a new owner and am like a fish out of water...
if you have access to the ends most cables have the part number and length embossed into the plastic. some list the length in inches and some in feet and inches. if you can find the numbers someone can tell you what you have.
Its not a fountain, its a Spectra. But I got my cables from Outdrive Exchange is Huntington beach.
