-   -   is there a cheap way to do hydraulic steering hoses? (https://www.offshoreonly.com/forums/do-yourself-boating-budget/255514-there-cheap-way-do-hydraulic-steering-hoses.html)
regalman4925 06-09-2011 04:03 PM
im tyring to get the rest of the hardware for my hydraulic steering setup on a tight budget. is there any cheap way to doing hoses? also does aanyone have the through hull fittings and/or the hose going back thhe the ram? i have everything else ready to go and really wanna get thiss on this year.
eddie 06-09-2011 04:40 PM
You shouldn't have a problem with time, the river is a total mess! Some of the Dodge Park guys headed to LOTO for the year. Do you konw Pulte? He might be able to steer you in the right direction.
regalman4925 06-09-2011 05:28 PM
the river situation sucks terribly but that isnt slowing us down. we have been out at manawa (ya i know it sucks but its all we have close) and have plans for harlan county soon, okoboji in august and possibly loto if i can find a sitter for another weekend. i am not sure who pulte is... i am not letting the flooded river get the best of me :)
baja_brian 06-09-2011 06:01 PM
Just use lots of tape and wire. You should be good after that. :lolhit:
If you head down to loto let me know, I am there almost every weekend.
I was thinking about Okoboji just the other day. I was craving some of them "better than sex" pina coladas.
eddie 06-09-2011 06:09 PM
I'm also at LOTO every weekend, but use to have a house on Carter Lake. They did a recharge on the lake it's very clean now.
I'll PM you Bob's number he might have some ideas for you.
fireboatpilot 06-09-2011 06:10 PM
If there's a fork lift repair shop near you they can make then up. Their a weird size fitting, #3 I think for hydraulic lines.
POWERPLAY J 06-09-2011 06:33 PM
They are cheap to make. Ask the mechanic that does your service work
bustedbrick 06-09-2011 07:55 PM
I used two thru-hulls with a "T" on the outside of the hull to save holes in the transom and run fewer lines.
I have two extra bulkhead fittings you can have for shipping. They are basically just pieces of heavy wall stainless with NPT threads cut on either side. I used a 9/16" NF tap to continue threading down a portion of the fitting, allowing me to use a jam nut separate from the NPT fittings. Anyway, IMHO, to have a proper bulkhead fitting, you'd need to do the same.
For hoses, you can buy reusable fittings and assemble the hoses yourself (don't need a crimping machine). You can get fittings and hose online.
n20michael 06-09-2011 11:16 PM
Any "hyraulic" place should be able to make them for you, "up here" I use a place called Princess Auto, they sell lines, fittings, pumps, etc and will make lines with fittings for you on the spot. Maybe have a look in the yellow pages under hydraulic?
Good luck
Michael
Griff 06-10-2011 01:20 AM
I checked several hydraulic shops in the Omaha area when I had a hose leaking on my Pantera. Nobody had the fittings with the correct flange angle except the Aeroquip dealer just south of 108th and Harrison St.
I'm pretty sure you know, or at least know who Pulte is. He has the light gray 28 Baja with big power and monster stereo. I know you have both been down at Rick's at the same time before.
regalman4925 06-10-2011 07:06 AM
that is gonna have to be some killer tape lol
loto is in the works, also okoboji and harlan county. harder to get away for a weekend with kids...
regalman4925 06-10-2011 07:15 AM
im gonna have to check them out or order online. i like the idea of the reusable fittings.
does anyone know the correct fitting flange angle i need?
i think the hose is a -6 or 3/8" if i am not mistaken. does anyone know the difference between 1 wire and 2 wire?
does the return line need to be the same as the rest of the system? or can i use the same hose with some type of slide on and clamp fitting? it is not under the amount of pressure everything else is...
doesnt seem like any of the manufacturers want to give out the info onine for stuff like this... latham especially has very little info online for guys like me that are piecing together setups. :(
griff, now that you say what Pultes boat is i know him, talked to him several times last year. that baja 280 is the next model i am looking at buying. his motors are SWEET! nice guy
showtime83 06-10-2011 06:31 PM
I just got done doing all my steering lines. All but my return are -6 JIC. The return I used npt/jic in the the cooler, then push loc jic's.
regalman4925 06-11-2011 08:00 AM
does this part # sound right?
AEROQUIP # FJ9122-0806S
Female (37 Degree) JIC Swivel
regalman4925 06-11-2011 08:29 AM
ok thats wrong it think this is it FJX-06-05?
which is -6 or 3/8 37 degree female swivel 5/16" thread
regalman4925 06-11-2011 09:42 AM
i have the option to buy latham thru hull fittings for 50 each and includes 1 90 deg fitting each which looks to be about 15 each and then buy rubber hoses OR i can buy a stainless thru hull kit from cp or hardin and get 2 thru fittings, 4 90s, the fitting on the outside is attached so that pretty much knocks out 6 stainless fittings that are roughly 15 each so 60 total in fittings and i get stainless braided lines to the ram for 180 bucks. if i buy the latham ones i am 100 on the thru hulls, 60 in the 4 other fittings i need on the outside of the hull that doesnt have the hoses. ok, thats figured out
my helm has male adapters on it, it was a imco helm so i am assuming based off of their website (much better than lathams!) that they should be -6 JIC which they list as 9/16"-18 thread 37 flare which sounds right to me. what is throwing me off is the bajo fitting i need for the steering pump is listed on cp with a 5/16-18 Thread X -6AN... so what i am thinking is that the 2 lines to the rams will be identical -6 9/16"-18 thread? and then the hose for the pump is gonna have 9/16 on the helm side and 5/16 on the pump side? then the return line will have a 9/16 on the helm side and a slip on fitting on the cooler side. does this sound right or am i all sorts of confused?
baja_brian 06-12-2011 10:46 AM
I am not sure. I just used lots and lots of PURPLE tape.
showtime83 06-12-2011 06:32 PM
I made all mine with hose that was overkill, I think it is rated at like 5500psi or something, all my fittings on my hoses are -6 jic, reusable they call them. I think I used parker fittings, that are stainless. the only hose that is push lock is my return, however they slide into the hose, then have a -6 female jic, going into the cooler the fittings are 3/8npt male- 6 jic male, that way I never have to cut the hose to get them off, just put a wrench on them. The thru hull fittings were npt to jic. I hope this helps out better.
