Best intake gaskets for mag 502 >
Old 06-23-2011 | 09:22 PM
GPM
They would probably work without the extra bolts but the holes are there use the bolts. The CPs look like the Felpro printoseal, did the Cometics come from Summit ? Can you exchange them for the Felpros ?
GPM is online now
Old 06-23-2011 | 09:33 PM
I got them from summit there getting sent back. I was hoping to have the boat going for the weekend. I'm going to order the CP ones.
haulinit is offline
Old 06-23-2011 | 09:54 PM
Ted G's Avatar
I got the Mr Gasket ones last time and they are really nice, lots of meat around the water ports. I see you are using the Cometic head gaskets, were both the heads and block machined to the correct spec? My machine shop guy would not let me use them because the block deck had not been machined to the proper spec.
www.cbpba.com
Ted G is offline
Old 06-24-2011 | 08:55 AM
The block has been decked before but not between me changing head gaskets. The Cometics are the same thickness compressed as the FEL-PRO ones. I guess I'm confused on what spec your engine builder was referencing? Flatness?
haulinit is offline
Old 06-24-2011 | 09:05 AM
Ted G's Avatar
There is a smoothness spec (RA- roughness average) that is smoother than normal, here is the note from Cometic's website:
A surface finish of 50 RA (roughness average) or finer, is recommended for a proper gasket seal. Anything rougher may conflict with the gasket design.
My guy said that unless you specifically machine for this then it will not meet the spec, you may want to check with your machine shop.
www.cbpba.com
Ted G is offline
Old 06-24-2011 | 12:55 PM
The FelPro 1211S-3 has the extra bolt hole and the steel layer for strength. That's all my engine builder recommends
ThisIsLivin is offline
Old 06-24-2011 | 06:40 PM
Originally Posted by ThisIsLivin
The FelPro 1211S-3 has the steel layer for strength.
That's the key... Makes it a much better gasket than the 1211
He's a smart guy...
cubicinches is offline
Old 06-25-2011 | 08:17 PM
Kevlar is an aramid fiber.....just throwing that in.
JB33 is offline
Old 06-25-2011 | 09:11 PM
ballon78's Avatar
Originally Posted by haulinit
Cant seem to find the Kevlar ones just the ones made with aramid fiber. Has anybody used the Extreme marine ones from Hardin Marine?http://www.cpperformance.com/p-11759...ular-port.aspx
i like the hardin ones the best, real heavy duty, seal very well around water ports. have used on a few 502's
i bought felprs, mr gasket, merc ones and hardins worked the best
96 HUSTLER 32, Vacuumed bagged layup, composite transom Blueprinted 502EFI's Mayfair, Dry-exhaust
ballon78 is offline
