Need to clear codes on a 2006 350 Mag MPI >
Old 06-21-2011 | 10:03 PM
phughes69's Avatar
Default Need to clear codes on a 2006 350 Mag MPI
Does anybody in the Metro Detroit area have the diagnostic software to read and clear codes for a 2006 350 Mag MPI with the ECM 555 computer.
I got a tank full of bad gas and it caused the knock sensors to go haywire and set a code. Since then I emptied the fuel and changed the fuel filter, but the engine still flashes the "alarm" on the smart craft display tach. from what I read the only way to clear it is with the Rinda software and the dealer wants minimum $95.00/ hr just to clear it.
phughes69 is offline
Old 06-23-2011 | 09:31 PM
If it is still flashing alarm then you still have a problem. The knock sensors will not have to be reset, it the problem is gone then the code is stored but if the problem is still there then then you need to find it. Check your drive lube bottle, is it full? You don't know how many boats come in the shop with the alarm sounding and its the drive lube bottle.
00 Daytona 22 is offline
