Procharger Oil Problem
Old 07-29-2011 | 07:35 PM
Default Procharger Oil Problem
My procharger oil is turning BLACK, this is on a self contained unit
M3SC, only 20 hours on it since a complete rebuild by ATI,
I changed the oil after engine break in , then every 5 hrs after that, gets black after first use
ATI reccomends to change it after 100 hrs , oil is very black, some very fine stuff on the drain plug but nothing to be concerned about.
Does anybody use anything besides Procharger oil ???
tech said to flush it with motor oil by filling it and starting it
several times, but do not run it under boost, just idle.
outlaw is offline
Old 07-29-2011 | 10:38 PM
Default Fixx
i wouldn't think you should see anything on the plug,maybe you may have a defective bearing,i would send it back before it self destructs ..is the belt too tight?
FIXX is offline
Old 07-31-2011 | 08:41 PM
have the same unit, mine does not do it...seems bearing is going....call them
ezstriper is offline
Old 07-31-2011 | 09:23 PM
offthefront's Avatar
I would definately get them to look at it ....what did a rebuild include? If you dont mind about how much was it? ............m
offthefront is offline
Old 08-06-2011 | 10:09 AM
EDIT
pulled the belt off and the bearing on the input shaft is fine, impeller bearing is sloppy
time for a return trip to ATI
29 hrs on the boat since a complete blower rebuild..... this SUX
Hopefully I can get it back for our labor day trip
outlaw is offline
Old 08-06-2011 | 09:22 PM
EDIT
bad ..... but at least you found it before a major blow up .....
