-   -   Closed cooling systems (https://www.offshoreonly.com/forums/do-yourself-boating-budget/262915-closed-cooling-systems.html)
airshares 09-24-2011 09:47 PM
Im thinking of adding closed cooling system to a boat Im buying. I operate in the salt water 100% of the time.
Does anyone have experience with these and are they worth the money?
The engines I want to put them on are the Mercruiser 350 Mags.
ezstriper 09-25-2011 03:28 PM
yes, in salt water a great idea...saves the engine and manifolds...
BUP 09-25-2011 04:57 PM
Give a call to Mr.Cool they advertise up here and can answer all your questions plus have good prices.
airshares 09-25-2011 09:49 PM
Thanks!
Thanks for the help guys. I will look up Mr. Cool.
KEPP 09-26-2011 11:16 AM
closed cooling
Here's an option as well http://www.keitheickert.com/p-14010-...o-360-cid.aspx
airshares 10-03-2011 12:24 PM
@ Kepp
With the EconoCool system I still use sea water to cool the manifolds? With the closed water system how do I do flush the manifolds?
CIG3 10-03-2011 12:44 PM
The KEPP ststem would take the water from the heat exchanger and run it thru the exhaust manifolds and out.
A fully closed system would also run antifreeze thru the manifolds.
MikeyFIN 10-03-2011 01:47 PM
How do you think you cool your engine??
* Think for chrissakes...
ozarkdevil 10-03-2011 02:03 PM
There is no need to be an a$$...
MikeyFIN 10-03-2011 02:51 PM
Well I rather be an ass and make him think before some else is an A$$ and takes his money for a simple flush. This is a No-brainer.
