-   -   6.2 IAC Motor (https://www.offshoreonly.com/forums/do-yourself-boating-budget/263191-6-2-iac-motor.html)
Trash 07-10-2013 09:35 PM
Originally Posted by vettex1 (Post 3956668)
what exactly does this IAC Motor do? I have HP 500 EFI's, will those numbers above for mine too?
Helps control the idle by adjusting air flow through the IAC pintle. Effectively it has an air inlet and needle valve that is continuously driven open or closed either allowing more or less air into the manifold to stabilize idle on EFI motors.
http://www.offshoreonly.com/gallery/...e=19168&size=1
vettex1 07-11-2013 10:52 AM
Thank you very much for that.
