serpentine vs v-belt
I thought about doing it but the cost was HUGE! Then I thought about it some. You don't see to many high HP motors with Serp. belts on them. Why change what works. I think that the V-belts give you a little more room up front as well it seems.
Put your best foot forward!
I think the loss of HP is probably small. So it comes down to cost. Tons of money for.....???
Depending on the engine family size and HP, belt type may be a small thing to consider. If you will be spending good money and boating in salt water, use the money to go with the closed cooling and a good aluminum head equipped engine. In less you have a good annual budget for supercharging I would recommend staying with a reasonable HP normally aspirated build and being able to use standard less expensive Bravo drives. Kind of a good piece of advice is to set your max budget $$ now and work backwards from there so you can complete your project and GO BOATING!! If your putting money in a smaller older hull it just does not make a lot of sense to put big expensive power in it unless you've got a good bottomless budget to set up and use all that extra power!
Best Regards,
Ray @ Raylar
Best Regards,
Ray @ Raylar
THANKS for the response. I'm doing a shp, afr, Madara build. 450h 500t goal. To clean the front end up I'm going to relocate the p/s pump to mid starboard side(knowing it's a big deal). Alt on lower port, moving up to mid also. So far it sounds like a 50/50 vote. Have more threads to follow. Thanks again for your valued input. R.
Serp belts will out last a traditional v-belt, lower maintenance is the main reason you see them on cars. Remember when service stations had thousands of v-belts hanging on the walls in plain site? Was a very common replacement. You would be able to keep one spare belt on your boat and have p.o.m.
However- You could lose an alternator, or ps belt on a v drive set up and still get home without a spare. The single dedicated belt on the sea water pump along with battery power for the ignition will keep you going. However my experience is the one that goes is always the one you don't have a spare for, or the one that requires taking all the others off
I too have been considering doing this conversion on my current engine builds. Not wanting to spend to much money as the benift is only a cleaner look and easier maintenance when removing/replacing water pumps, sea pumps, alternators, etc..... Please keep me inform on you build as you find the parts, hoping to find aome automotive excange parts from salvage yards to ease the cost.
Cliff
Cliff
