Relocating Water Pressure Line >
Old 12-07-2011 | 06:48 AM
Default Relocating Water Pressure Line
When I upgraded my guages last winter the new water pressure gauge came with about a 1/16th line that I installed at the drain plug on the engine. The old one was about a 2/8th line that was also attached to the drain plug. Anyhoo, when I winterize this year I found the line was totally clogged with rust and crap. Would like some suggestions/opinions on where would be the best place to relocated the line/fitting on the engine (gen6 502) that will minumize the clogging problem. Thanks...
Thunderstruck27 is offline
Old 12-07-2011 | 08:22 AM
jbraun2828's Avatar
Top of the intake will work.
jbraun2828 is offline
Old 12-07-2011 | 12:31 PM
That's exactly what I'm thinking. With the obvious drawbacks to the original location...I'm wondering why they (boatbuilders) install them there in the 1st place.
Old 12-08-2011 | 09:04 AM
Some oil coolers have drain plugs on them. Ive used them for water psi gauge lines with no problems.
MILD THUNDER is offline
Old 12-08-2011 | 12:28 PM
Good idea...I haven't noticed one on my oil cooler, but i'll check that out when I get to the lake. Thanks!
Old 12-08-2011 | 07:14 PM
jbraun2828's Avatar
also a sea strainer would eliminate the problem
Old 12-08-2011 | 07:32 PM
i use a 1/8 inch line from the back of the intake manifold,i also run #3 line from back waterports on intake manifold overboard to eleviate any possibility of steam pockets in the block.
mike tkach is offline
