540 carb???
Old 12-08-2011 | 10:06 AM
swan2's Avatar
Default 540 carb???
I built a 540 with AFR alum. heads what carb. is recommended for this thanks for the help in advance.
swan2 is offline
Old 12-08-2011 | 10:21 AM
What size heads, cam, intake and comperssion?
goebel1 is offline
Old 12-08-2011 | 11:19 AM
swan2's Avatar
Im not real sure I ordered the afr marine heads from a shop a few years ago new and the cam also they have since then closed down and im not sure the specs. There is like a serial number or something on the side of the heads I can try and get that number if it helps. I dont really know what to do at this point.
swan2 is offline
Old 12-08-2011 | 11:57 AM
Look on the front of the heads there will be a number like 315 and if there is CNC following the the number then they are 315 CNC AFR heads
goebel1 is offline
Old 12-09-2011 | 09:07 AM
swan2's Avatar
Ok I checked the number on the front and theres a 325 does this mean anything? And they are afr alum. heads.
swan2 is offline
Old 12-09-2011 | 10:07 AM
This is what they are http://www.airflowresearch.com/index.php?cPath=68_72
So you have no clue what your compression or cam is? Is this a blower motor or N/A.
goebel1 is offline
Old 12-09-2011 | 10:12 AM
im guessing it is a n/a motor,540 with afr 325 heads 850 cfm carb will work.
mike tkach is offline
Old 12-09-2011 | 10:32 AM
I made 738HP on my 540 with 315 cnc heads 9.1 compression Edlelbrock victor jr. intake custom cam with a Berry Grant 1000cfm 4150 style carb. I change to a ProSystem dominator 1050cfm carb and a edlebrock 454 victor intake and pick up 3MPH. Dont have any dyno numbers thou.
goebel1 is offline
Old 12-09-2011 | 11:14 AM
Originally Posted by goebel1
I made 738HP on my 540 with 315 cnc heads 9.1 compression Edlelbrock victor jr. intake custom cam with a Berry Grant 1000cfm 4150 style carb. I change to a ProSystem dominator carb and a edlebrock 454 victor intake and pick up 3MPH. Dont have any dyno numbers thou.
wow,thats a lot of power for a 9 to 1 motor,what rpm did it peak out at?
Old 12-09-2011 | 11:15 AM
6200 RPM
goebel1 is offline
