-   -   Scarab wouldn't start today (https://www.offshoreonly.com/forums/do-yourself-boating-budget/267018-scarab-wouldnt-start-today.html)
airshares 12-10-2011 10:42 PM
Its a 1997 Scarab with 350MPI's
My starboard motor wouldn't fire today. It cranked and cranked but no fire. I want to try replacing the lanyard kill switch and ignition switch first....or other ideas people can suggest?
I did not check to see if it was getting fuel but I did smell fuel from cranking it.
The port motor fired right up.
One thing Im not sure if this is normal but I noticed the kill switch is touchy. I turn the key and the alarm goes off as normal but after I crank it i notice the oil pressure come up as it should but then the voltage goes to zero when i stop cranking it and the alarm is gone.
I have to turn the key back off then back on again to get the alarm and voltage to show.
c_deezy 12-10-2011 11:25 PM
Possible its the key switch. Had one do something similar before. You can verify it with a multi-meter prior to replacing it, same with the kill switch.
mike tkach 12-11-2011 12:53 AM
maybe check and see if it has spark when you are cranking it,i had a similar problem,it was the safety lanyard switch,one thing i am sure of,anything electrical is prone to failure.
mr3dman 12-11-2011 02:00 AM
You can bypass the kill switch and key ignition by applying a 12v jumper to the coil positive side (purple wire). If it fires you know it is either the key or lanyard at that point and can narrow it down from there. If it still won't fire, check for spark. If no spark you prob have a bad coil. if it fires with the jumper, you have to pull the jumper to kill the engine, btw....
airshares 12-12-2011 12:04 PM
I looked at Eddie Marine and those aren't the same kill switches I have. Mine have little red buttons on them that are held in by clips. When the clip is removed the buttom pops out and kills the motor.
I've been looking around online and I cant find the same ones yet.
Griff 12-13-2011 01:17 AM
The alarm goes off because there is no oil pressure. When you crank it over, it creates enough oil pressure and the alarm quits sounding. That is normal.
You need fuel and spark for the engine to fire. Pull a plug wire and see if you are getting spark before you start replacing parts that are fine.
airshares 12-13-2011 07:37 PM
Im gonna replace the kill switch anyway. They were cheap. Plus the thing was really touchy anyway.
I am suspect of it because last time I went out i was heading out the channel and the starboard motor shut off on me. It restarted but I think i messed with the kill switch to get it running again.
airshares 12-19-2011 12:09 AM
Wasn't the kill switch. I pulled the spark arrestor and carb didn't look wet. But It was hard to tell. I was there by myself so I couldn't see if fuel was flowing while trying to start it. Im gonna have the mechanics come out this week. Will post what it was when they find it.
Griff 12-19-2011 02:00 AM
Disconnect the throttle cable at the carb and pump the carb. It should squirt fuel.
Take off the fuel water sep filter and see if there is fuel in it.
cliff_m_b 12-19-2011 12:12 PM
@ airshares,
For future reference you should have a solenoid on back of the motor somewhere around the top of the bellhousing, (should have the big red wire going to the starter and the yellow-red starter wire to it) with a remote starter switch attached to it you can spin the motor, (a screwdriver across the terminals to short it out will do the same thing but not recommended because of sparks and damage to the terminal ends) over by yourself making it a lot easier to work on your motors by yourself.
Cliff
airshares 12-19-2011 09:37 PM
Thanks Cliff that is helpful. As you can tell I've never worked on boats let alone motors of anything really. lol.
Im having the mechanics look at it tomorrow but its good info to know for future issues
airshares 12-21-2011 01:30 PM
Update
Well problem solved. It was a faulty Fuel Pump. $700.00 later boat runs. The parts were $180. But I didn't do the labor and the mobile marine place charges me $195 to show at my dock.
Now its time to tear out the interior for re-doing.
