1996 mercruiser 7.4 mpi efi NO SPARK AGAIN >
Old 01-11-2012 | 06:19 PM
Default 1996 mercruiser 7.4 mpi efi NO SPARK AGAIN
Hello again guys my 1996 7.4 efi mpi has intermittent spark problem , ive changed the Coil,Pickup,Module,cleanded all the connections checked the grounds i could find and still no luck , i can go to the dock in the morning start it up go fishing turn it off and one 10 times moving from spot to spot then the eleventh time no spark wait like an hour and start up and go like nothing ever happeded, dock the boat start it up, like three times everthing is good go home come back the next weekend and go to start it and NO SPARK again im Puzzled at the least im ready to take my 416 weatherby magum to it, an help would be much appericated Thanks James
jimmie is offline
Old 01-11-2012 | 07:01 PM
Just a thought..... Do you have one of those safety switches that hooks on a lanyard that kills the motor if you were to fall overboard? Perhaps check the switch and make sure the connections are tight, not sure but I think that has something to do with spark.
Good luck!!
bajaboy217 is offline
Old 01-11-2012 | 07:13 PM
No I Dont Think So Never Seen That, But Thanks For The Input
jimmie is offline
Old 01-11-2012 | 07:31 PM
Default No spark
When you say no spark you do you mean the motor will not start or do you mean if you pull a plug and hold it while some turns the key that it does not shock the **** out of you.. Just kidding but we need to know if the plugs are firing or not.
Chris
Blueabyss is offline
Old 01-11-2012 | 09:50 PM
Plugs Are Not Firing
jimmie is offline
Old 01-11-2012 | 10:36 PM
What boat is this in? The reason for that question is that it really could be a kill switch that you don't use and it could be failing.
mr3dman is offline
Old 01-11-2012 | 10:45 PM
Its In A 26 Nova Wellcraft I Rebuilt It Had Twin 302s And I Did A Repower With The 1996 7.4 And A Bravo 3 Outdrive I Bought The Wiring Harness New And Guages And Had A Electrian Do The Electric. Their Is No Neutral Safty Switch In The Control Box And Not One On The Motor,
jimmie is offline
Old 01-11-2012 | 10:53 PM
hell, that makes it interesting doesnt it? If it were me, the next time it happened i'd check for 12v + and - at the coil when cranking then go from there. if you have 12v going to the coil then you may have a bad pickup, module, etc even though you already replaced them. If you don't have 12v pos and neg! then the problem is in the wiring or ground. Just some ideas to try
mr3dman is offline
Old 01-12-2012 | 11:54 AM
I had Bravo 2's with my last Amberjack. One would do this occasionally. I ended up finding that the connector where the harness would have normally been connected to a shift cut-out switch (if I had had Alpha installed) was shorting occasionally. The plug to cover the harness was jacked up. I swapped between motors and the problem, although intermittently, moved. That shift-cut out switch was to momentarily cut-spark to the engine to "stall" the motor for a split second to reduce torque when shifting into/out of neutral. The end result of the bad plug was what you are describing. Shake you wiring harness.....
Redhook98 is offline
Old 01-12-2012 | 12:26 PM
Unplug the harness and put some dielectric grease in the terminals and plug back up. Also might want to run a new ground to that motor. What is your battery configuration?
Chris
