Aluminum Manifold
Old 01-18-2012 | 12:39 PM
Default Aluminum Manifold
Is there some kind of an anode that I have to have, if I use a non-marine aluminum manifold? Think I read that somewhere.
Thanks!
gvmv2001 is offline
Old 01-19-2012 | 06:58 PM
offthefront's Avatar
no .....just flush after every salt water use ....
offthefront is offline
Old 01-19-2012 | 08:07 PM
I disagree. I had 420's that came with aluminum manifolds and I flushed them for 15 minutes avfter every use. In 3-4 years a pit formed underneath the thermostat and bore a hole to the point they leaked. I replaced them with manifolds that had a brass sleeve in the crossover.
JTeam is offline
Old 01-19-2012 | 09:24 PM
Sounds like you had a ground issue turning your aluminum manifold into a battery. Aluminum manifolds on trailered boats are fine if properly flushed.
charliem is offline
Old 01-19-2012 | 09:54 PM
Also makes another point for shutting off your batteries after use.
f_inscreenname is offline
