Recommended transom assembly sealer.
I am about to install the "new to me" Bravo Transom Assemblies and looking for guidance on what the preferred sealer is for this job. I thought about 3M 5200 and then thought HELL NO that's too severe. Any suggestions?
Didn't use any sealer on mine, just put them on. Didn't see anything from the Merc installation manual recommending any type of sealer. Assuming you will be using the new large seal, that should be all that's needed.
i have taken more than a few boats apart they never had any sealer on the transom assembly just merc rubber gasket i must admit i have seen the start of transom rot not sure if it was leaky bolts or the gasket
Just an FYI, this stuff is supposed to work well for removing 5200.
http://www.westmarine.com/webapp/wcs...4804&langId=-1
our transom assembly started to leak so we used some 3M sealer. technically the large gasket on the housing should be all that is needed to seal in the transom. in our situation, i think the salt water ate through the aluminum and started leaking though the back side of the gasket.
