Mercruiser 454 mag re-power!
I am in the middle of a 454 mag rebuild to reporter my 98 model 25 outlaw. It is .030 over the cam specs are below. The cylinder heads are aluminum with 119 cc chambers and by the compression ratio calculators I have found on the net say it will make 10.33 to 1 compression ratio. It will have a Holley 715 cfm carb on it I am looking for recommendations for how many rpm this engine can safety handle reliably, and a recommendation on an intake manifold for this engine I am currently looking into a world Merlin intake unless someone can reasonably recommend something better. If more info on the engine is needed please ask I will tell all that I know. Also I have bought total seal gap less rings for this engine, also I have bought rocker stud girdles because I have never had many encounters with aluminum ears and figured they could only help. Any recommendations are greatly appreciated!
Intake Duration at 050 inch Lift 218
Exhaust Duration at 050 inch Lift 228
Duration at 050 inch Lift 218 int./228 exh.
Advertised Intake Duration 276
Advertised Exhaust Duration 286
Advertised Duration 276 int./286 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.500 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.500 in.
Valve Lift with Factory Rocker Arm Ratio 0.500 int./0.500 exh.
Lobe Separation (degrees) 114
WO1 Bradley Weaver
WO1 Bradley Weaver
I have had great luck with those rings in racing engines when I was in my late teens and early twenties they typically have a leak down percentage of only about 2% or so, but that is my opinion and those are already purchased. I can still exchange the cam what would you recommend if you think that is not enough? I am looking for decent power but also reliability ease of tuning and longevity of components. I know I am asking a lot!
you need a cam with more duration to cut down that compression....a bit high for a marine engine....crane 741 is a proven design and is just an example of what you can run...i've never done any business with bob madera,but i heard only good things about his expertise on cams....call him
I would recommend an Edelbrock RPM Air Gap intake and a 800 or 850 Holley.
Crane 168731 camshaft, 288/298 duration,587/610 lift, 112 LS
Scorpion Roller Rockers
What are the pistons that you are running? Something with a little dome to them. That seems like a lot of compression.
What kind of exhaust are you going to run with this?
As for RPM I would think to prop it for 54-5600rpm.
The pistons are speed pro forged with. -23.1 cc dome. As for that camshaft I was told to avoid any cam with less than 114 LS because of the chance for sucking water back into tthe engine . I. Was planning on just stock manifolds as the rebuild has already exceeded my budget by over $1000 and quickly eating away at more than that. Big performance exhaust will probaly not happen until next winter.
You need to upgrade your exhaust or you are throwing money away. You always start with the exhaust system for any good marine build.
Also unless you plan on running expensive gas, I would lower the compresssion or risk the chance of a melt down.
