looking for 100hp 10 mph
61 mph? around 5000 rpm wot? do the exhaust like Big Jim said, and 23 prop and you will be around 67-8 with paid for 454. you need those 2 pieces first anyway before anything else will do what it is supposed to. what heads are they? peanut, or oval?
Butteboy has posted about the speed and prop in another thead. He tops out @ 4800 with a 20" 4 blade. That is 9% slip, just below the limiter. It could be a bit more 62ish with an M+ 21" @ 4600-4700 but with that setup 61 for the 300 hp @ 4800 is right on the money. An exhaust upgrade can give you a little as you said, but I'd suspect it to be from the weight saving.
67-68 with the 454 300? Never in a million years.
I agree with your engine guy. Put the blower on and have a ball with it. 30* all in timing and no more than 12af at wot. Nice thing to have would be inconnel exhaust valves and cometic head gaskets if you are going in to the engine. Another nice thing would be to switch your upper gears to 1.5s. You will really like the pop from that little blower and will see an easy 10mph with 5psi. No need to touch exhaust, heads or cam the blower will crutch it all up.
When you are currently running 61, you should easily be in the 70-72 mph range with a 502. Many boats with that power, heavier and slower than yours, run 68-70 with the 502. The 502MPI is a better choice than boosting the 454. Less headaces and likely money saved down the road. I'd also say that resale is better too when time comes, the Merc 502MPI is a popular motor. BTW, if your motor is a non mag from '96 you have either the 7,4L 300 4B carb or the 7,4LX EFI 330. In '97 there was the 7,4L 300 4B carb, the 7,4LX 300 EFI and the 7,4LX MPI 330. The mags in '96 and '97 were the 454MAG 350 4B carb or the 454MAG MPI 385. The 7,4L MPI 310 showed up in '98,
To my knowledge and memory, all the non-mag 454's had cast internals all the way around, not ideal for boost. A 502 with a Baja labbed 23" M+ will make that thing really cool. Consider hydraulic steering
No it's 4200-4600.
thanks for the support on the blower blue thunder and AO i agree somewhat with you on the overbuilt thing. i mean its not really a possible thing more so just wasted money up front and thats what he said " marine stuff costs so much because its got a warrentee not ment for people who know how to lift or tune or anything just pin them and get upset when it breaks" so i understand where he's coming from and we go back a bit he's helped with my 500 hp na 650 on button so i mean tunning i can do but not so much this boat stuff my safe idea is keep timing low and throw extra fuel at it
the ringer is my dad is the one who suggested second motor build so when i find another boat in 3-5 years at soonest gotta get life/ gf wife thing all square first
blown hammer your hull is realistically faster esp power for power thanks for the support
and i actually traded a blown up 4.6 ford for some 049 heads with new inconel ex valves TODAY
