Flushing a Latham Steering System >
Old 03-08-2012 | 07:56 AM
CIG3's Avatar
Just drain the reservoir, pump, cooler and lines as best you can. Refill and bleed thru lines at cylinders as normal. As said in previous response. It's gonna take alot of fluid but should work fine. May take a couple runs to get it all.
CIG3 is offline
Old 03-08-2012 | 08:24 PM
Are the Marine Machine filters cleanable?
SkiDoc is offline
Old 03-11-2012 | 11:20 AM
Originally Posted by OPIE272
Or
Take the external steering lines off the actuator at drive.
Have a LOT of fluid available. As in Gallons!!!!
Remove one end of the steering lines and place in a "dump" bucket.
Take the other line and insert into a container of fresh fluid.
Start the motor and get the fluid running.
Turn steering wheel whatever direction that causes the fluid in the fresh bucket draw into system and reject into the "dump" bucket till fluid runs clear.
Thanks for the detailed information. This is the system that I will us the flush it. I already have a filter in the system that I am assuming is on the supply line. One a single ram system I am thinking the supply line goes to the port that is closest to the piston when the piston is fully extended? Is this correct?
Also is there any considerations that I need to worry about with the reservoir? Is there a chance of it over filling?
TW720HVY is offline
