What did I do wrong?
Old 05-03-2012 | 05:00 PM
Start checking every wire and connection and anything that that you moved or touched. Why is there a black/ground wire laying on top of the dist and not connected to anything???? and a purple(key on hot) wire laying across/on top of the shift linkage???
Griff is offline
Old 05-03-2012 | 05:04 PM
they werent connected to anything before....
magnum350 is offline
Old 05-03-2012 | 05:59 PM
Originally Posted by magnum350
I don't know much about these ignitions. Which one do I have?
Look at the ignition module, it is mounted to the exhaust riser on the port side (passenger side) of the engine, opposite side of the engine of the shift linkage. It will clearly state if it is thunder bolt IV or V. Should be V unless somebody changed it. V has a knock sensor, IV does not. Maybe other differences but I am not aware of them.
87MagnumII is offline
Old 05-04-2012 | 09:41 AM
It is a Thunderbolt IV
Old 05-04-2012 | 10:31 AM
Wink
Looks to be a black unconnected ground wire and if its got a connector like that and its not bolted down as a ground or such the install might still be in error?
Check the plug wire connection on cylinder #5 and #7, many times these two get crossed because they are right next to each other in the firing order and I've seen some run like this with that cross-up.
Best Regards,
Ray @ Raylar
Raylar is offline
Old 05-04-2012 | 03:46 PM
I'll double check the wires, but none of them were ever removed from the cap or the plugs and it didn't run like this before.
Old 05-04-2012 | 05:35 PM
1 MAIDEN AMERICA's Avatar
I have a ground wire going to one of my cap bolts
1 MAIDEN AMERICA is offline
Old 05-04-2012 | 05:45 PM
I got the correct riser gasket for it today, so I'll get it changed and try hooking that ground up to a cap bolt. That ground and hot wire werent hooked up to anything before. It's worth a shot I suppose.
Old 05-04-2012 | 05:53 PM
what is on the other end of the ground wire? purple is probably trim limit. supposed to stop you from trimming up at a certain point when in gear. probably bypassed.
dereknkathy is offline
Old 05-04-2012 | 06:08 PM
A ground
