What did I do wrong?
Old 05-06-2012 | 11:22 AM
  #61
It's not in the timing. I put #1 on TDC and reset the distributor. Still running the same.
magnum350 is offline
Old 05-06-2012 | 06:03 PM
  #62
What is to total advance at 3000 RPM?
sprink58 is offline
Old 05-06-2012 | 06:05 PM
  #63
Ground wire!!!!!
DYVMASTER is offline
Old 05-06-2012 | 06:10 PM
  #64
Originally Posted by dyvmaster
ground wire!!!!!
+1
sprink58 is offline
Old 05-06-2012 | 09:44 PM
  #65
If it is TBIV you have to hook up that black ground wire. Stick it under the bolt that holds the ignition module to the riser. That's where mine is
87MagnumII is offline
Old 05-06-2012 | 09:49 PM
  #66
Mine has the module on the back of the distributor. It's not on the port riser.
Old 05-06-2012 | 09:53 PM
  #67
The reason I keep asking about total timing is that I think you might have accidentally shorted the module...you might be in "limp home" mode and the engine will not rev past 2000 rpm. This is exactly what happens when you loose a ground on TBIV.
This is a guess...but I think there might be something going on with the module.
sprink58 is offline
Old 05-06-2012 | 09:56 PM
  #68
it will rev past 2k no problem. its just kinda rough lol
Old 05-06-2012 | 10:05 PM
  #69
hey mag what part of ky are you in ?
jason y is offline
Old 05-06-2012 | 10:10 PM
  #70
Central KY. An hour south of Lexington.
