-   -   seafoam? (https://www.offshoreonly.com/forums/do-yourself-boating-budget/276036-seafoam.html)
seth0687 05-08-2012 05:02 AM
seafoam?
Hey guys,
Tried doing a search but didn't really come up with much. I have used seafoam in the past to freshen up car motors but haven't been able to see what people think of using in marine applications. Thinking about trying it to freshen up my Merc 502.
Opinions, advice, comments...concerns lol?!?
Thanks,
Seth
sleev-les 05-08-2012 05:46 AM
I use Startron in mine. I was using Stabil, but switched over. I've had no problems with Startron. I added it everytime I get gas.
rchevelle71 05-08-2012 07:13 AM
Use it in the outboard boat frequently, Not sure if it helps, but doesnt hurt. Just dumped 2 cans in yesterday for my keys trip nex week.
07DominatorSS 05-08-2012 08:01 AM
I use the AMSOIL Quickshot cause it handles all three issues I'm concerned with, injector cleaning, stabilization and ethanol stabilization.
http://www.amsoil.com/storefront/aqs.aspx
CrownHawg 05-08-2012 08:34 AM
Not sure what you mean by "freshen up", but I use Seafoam to maintain the fuel system. I don't think it's going to do anything to the actual motor, but it will help keep the fuel rail and injectors clean.
MCKILLOP 05-08-2012 10:05 AM
Seafoam also makes an oil additive that works well, however it will make your oil turn black pretty quick. whcih I guess is a good thing. I also like to use the throttle body aresol can.
modvp 05-08-2012 01:25 PM
I use the Startron too...but I also use seafoam at 1 oz/gal everytime I fill up. CRC makes a similar product that's more cost friendlier than seafoam.
relaxalot 05-08-2012 01:41 PM
I have a seafoam story. Its a true one. Before I went on a houseboat trip to Lake Powell I read a bunch of great stuff on how wonderful the product is on wayneswords website. There were all kinds of wonderful claims. I was very very skeptical... BUT when I saw it on the shelf at the store it just sorta jumped into my basket. I bought two cans. Well, the houseboat we were on was having problems with the generator. Two of my buds were working and working on it. They worked but could only get it to run for a while and then it would die. I told them lets try this stuff and poured one can in the tanks and a little into the intake line. It smoothed right out and ran perfectly the rest of the trip. Maybe water in the gas? I don't know.. I do know that it is a good item to carry just in case. Search wayneswords for more stories.
Twin O/B Sonic 05-08-2012 04:23 PM
I use a ton of it in our cars and boats. It will free up sticking rings in 2 my strokes. Everything I work on or buy, I warm the motor up and then hose it down (internally) right through the intake until it loads up and dies. Can says wait 2 hrs to re-start but I wait over night.
It smokes like a chimney the next day when you start it. I did a story about it on another O/B site and posted a picture of the black carbon ooze it puked out the exhaust.
Carbon'd up, sticking rings is the leading cause of death to a 2 stroke and that's why I treat everything I buy and then at least twice a yr after the fact.
I do the same to the cars. I'm driving a S-10 Blazer w/a Vortec V-6 with 252K on it and every once in a while it will start dropping a couple of injectors. I get the gas down to a 1/4 tank and dump a can in there (about 300% stronger than they recommend) then pull off the brake booster vacuum hose and w/it at high idle spray a can of their pressurized version in through the intake until it loads up and dies.
Runs like a top the next morning. Works great on the musquito's too ;)
seth0687 05-08-2012 06:03 PM
Thanks Twin, that was exactly what I have done in my cars and was wondering if it would be good for the boat....soundsd like it's a go.
Thanks,
Seth
stillcrazy26 05-12-2012 09:22 AM
I have used Seafoam for several years. Started using it for my Motorcycle. I choose it because of the added feature advertised that it was a rust preventive. When the gas tank on a new bike started to rust I looked for an additive to combat Ethanol. It did reduce and the eliminate the dust rust that had been visible. The negative thing that I see, is a lot of etching of the internal metal parts, such as the shut off valve,fuel bowl and carb. A real cleaner !
Some one ,unverified, said that it contains acetone. Anyone MS on it ?
I have now switched to another product from Power Resource Inc. nothing to report yet
