HP 500 oil temp
Old 05-28-2012 | 01:36 PM
Default HP 500 oil temp
I am runnning a 98 27 fever with and HP 500, and i was wondeing if anyone had any idea what my oil temp should be running at. When i am cruising at 3500-4000 rpm its running above 200 degrees. is that too hot sometimes it runs up to 215-220maybe.
98Fever27 is offline
Old 05-28-2012 | 01:39 PM
sounds perfect to me.....
2tonchevy is offline
Old 05-28-2012 | 02:42 PM
Good well that makes me feel better
Old 05-28-2012 | 08:33 PM
Ted G's Avatar
Anywhere between 210 and 280 is good. Less and it won't evaporate condensation and more and the oil breaks down faster.
www.cbpba.com
Ted G is offline
Old 05-28-2012 | 08:59 PM
200to 220 is perfect
mike tkach is offline
Old 05-30-2012 | 09:38 AM
Dave M's Avatar
Veteran: Navy
Is the same true for a 525efi? According to smartcraft, my oil is usually around 165, sometimes it will go up to the 180's.
I thought that seems low. My water temp is usually around 150 which seems low too.
I wonder if my t-stat is stuck open? Otherwise the motor seems to run great.
Dave M is offline
Old 06-03-2012 | 07:03 AM
ballon78's Avatar
oil thermostate on hp500 is set at 212, so thats perfect...
96 HUSTLER 32, Vacuumed bagged layup, composite transom Blueprinted 502EFI's Mayfair, Dry-exhaust
ballon78 is offline
Old 06-03-2012 | 11:40 AM
Dave M's Avatar
Veteran: Navy
I noticed in the 525efi manual that it said that the MAX oil temp should be 220.
Dave M is offline
Old 06-03-2012 | 12:05 PM
yes. I believe the alarm comes on at 220 on the 525EFI
MILD THUNDER is offline
