How to make this work?
Old 06-07-2012 | 11:16 PM
BUP
I sell those same t-stats kits but include 4 different gaskets as well for the orginal housings or different housing configurations. 25 bucks plus shipping.
BUP is offline
Old 06-08-2012 | 03:45 PM
scottw's Avatar
Thanks for all the advice everything is plumbed properly, thermostat is assembled in the proper order. The high flo stat could be a option. Going to try something this weekend. I'll let you know how it goes.
scottw is offline
Old 06-09-2012 | 09:06 AM
should temp guage be in thermo housing, or intake? i have one in each place...prev owner was running no t-stats. said as soon as temp gets off the cold pin, it was too hot...i hope to be finding out soon...
dereknkathy is offline
Old 06-09-2012 | 09:51 AM
Dont forget the cork or o-ring on top of the tstat, Alot of people forget and the stat will not seal properly !
speedreeder is offline
Old 06-09-2012 | 11:24 AM
Originally Posted by Griff
The newer style has an internal bypass system. You just run the hoses from the tsat housing to the bottoms of the manifolds. What kind of problems are you having????
Incorrect.......again.
i just dont understand why he posts when he has no idea what he is talking about,IF YOU DONT KNOW YOU SHOULD NOT POST INCORRECT INFORMATION,i think most have his number!
mike tkach is offline
Old 06-09-2012 | 12:23 PM
i am used to most big blocks being closed cooling. that is why that is first thing i asked. in retrospect, i shoulda realized this housing is raw water only.
Old 06-10-2012 | 06:08 AM
scottw's Avatar
Well it looks like I found the culprit to my problem. Who would of thought. Looks like It was cracked for a while cause the one side was not clean brass. Boat ran great the last run in October of 2011. Then made the changes with exhaust and T-stat housing and the problems began. What a coincedence.
scottw is offline
Old 06-10-2012 | 09:35 AM
Know anyone with a tig welder. Use to tit weld brass and copper all the time. LOL. Glad u found the source.
Noise Pollution is offline
Old 06-10-2012 | 11:42 AM
Good find!!!!
Griff is offline
Old 06-10-2012 | 11:49 AM
scottw's Avatar
Good find!!!!
Griff, my friend and I talked about it but only thought if the previous owner had put a automotive pump on there and it wore out the impeller. As we started to take it apart we thought this can't be the problem cause of the stainless backing plate it was a marine pump but sure enough it was broke inside.
scottw is offline
